1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: RE: Timezone setting with R3.14.10
To: "Thompson, David H." <[email protected]>
Cc: [email protected]
Date: Mon, 05 Jan 2009 10:20:12 -0600
Hi Tom, Happy New Year!
Thank you very much for your advice.  The return value of the "time" command
seems to indicate that my vxWorks clock is off by 6 hours, will talk to the expert
doing this.
Best regards,
Dehong
----- Original Message -----
Date: Sunday, January 4, 2009 1:53 pm
Subject: RE: Timezone setting with R3.14.10
To: Dehong Zhang <[email protected]>, [email protected]
> How does the local vxWorks clock get set?
> Epics time is # seconds since 1/1/1990 00:00:00 UTC and the basic
> vxWorks clock is from 1/1/70 00:00:00 UTC.  It should be easy to look
> at the return value from time() and the seconds field in a running
> record and see if the # seconds there is UTC or CST by just taking
> that number modulo the # seconds in a day.
> The timezone fields are only used for local time display purposes and
> would not impact what a camonitor would report.
> This is what we do:
> putenv("EPICS_TS_MIN_WEST=300")
> # New DST changes for 2007 Eastern Time Zone US
> putenv("EPICS_TIMEZONE=EUS::300:031102:110402")
> We also set the local vxWorks clock from NTP at the start, this makes
> the DST calculation go correctly.  The calls can be made from the
> startup script.
> ________________________________
> From: [email protected] on behalf of Dehong Zhang
> Sent: Tue 12/30/2008 11:36 AM
> To: [email protected]
> Subject: Timezone setting with R3.14.10
> Hi Everybody, Happy New Year!
> Recently we upgraded to 3.14.10 (on vxWorks 6.1).  We are trying to
> use the time
> from the local vxWorks system, instead of the EPICS time/boot server.
> So we do
> NTPTime_Shutdown
> immediately before iocInit.
> On the vxWorks console, we can see that the NTP thread is indeed off:
> generalTimeReport 1
> Backwards time errors prevented 0 times.
> Current Time Providers:
>     "NTP", priority = 100
>         Current Time not available
>     "OS Clock", priority = 999
>         Current Time is 2008-12-30 10:31:48.890000.
> Event Time Providers:
>         No Providers registered.
> value = 0 = 0x0
> Please note: the OS Clock does show the correct local time (US CST).
> But on a host machine, if we start a monitor process like "camonitor ..."
> we always get the time off by 6 hours.  It seems EPICS takes the CST time
> as the GMT time, then convert it back to CST.
> We tried both
> putenv("TIMEZONE=...
> They did not help.
> Please advice.
> Thanks much and best regards,
> Dehong
RE: Timezone setting with R3.14.10 Thompson, David H.
Prev: RE: EDM Horizontal Bar Szalata, Zenon M.
Next: Re: How to implement simple control algorithm (one more question) Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: Timezone setting with R3.14.10 Thompson, David H.
Next: EDM Horizontal Bar Szalata, Zenon M.
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
