1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICs base MingW32 compilation failed !
To: [email protected]
Cc: URIOT Didier <[email protected]>
Date: Wed, 7 Jan 2009 16:31:07 -0600
On Wednesday 07 January 2009 11:46:19 URIOT Didier wrote:
> I tried to compile EPICS base 3.14.10 on a windows computer with gcc 3.4.5
> I followed the install instruction, and compilation started correctly but
> after a fews secondes I had the following message.
> g++ -c -D_MINGW -O3 -Wall -m32 -D_DLL -I. -I../O.Common -I. -I..
> -I../../../include/os/WIN32 -I../../../include ../tcpSendWatchdog.cpp
> ../tcpSendWatchdog.cpp:73: internal compiler error: Segmentation fault
> Have you already see this type of problem ?
Yes, it's weird.  Sometimes I can get this file to compiler when I have
HOST_OPT=NO in my CONFIG_SITE file, but not always.  A colleague has no
problem on a different PC.  However even if you get past that problem you may
hit another one (which I'm also seeing on a cygwin build) that I haven't
worked around yet.
The Microsoft compiler (which you can download for free) does work for me
though.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
EPICs base MingW32 compilation failed ! URIOT Didier
Prev: EPICs base MingW32 compilation failed ! URIOT Didier
Next: Gateway fails with "epicsMutex pthread_mutex_lock failed: error Invalid argument" Mark Bennett
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICs base MingW32 compilation failed ! Jens Eden
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
