1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: USB streaming device to linux/epics
To: Emmanuel Mayssat <[email protected]>
Cc: epics <[email protected]>
Date: Fri, 09 Jan 2009 09:37:16 +0100
Hi Emmanuel,
I have only used USB/RS232 and USB/RS485 adapters. The P&P magic built into the Linux kernel maps them automatically to /dev/ttyUSB* where they can be used with asynDriver just like local serial devices.
For a custom USB device that is not automatically supported by Linux, I would suggest to write a Linux kernel driver instead of an EPICS driver. Have a look at http://www.linux-usb.org/
Dirk
Emmanuel Mayssat wrote:
Hello again,
I am contemplating writing a low level linux driver to read a stream of
data coming for custom made device and on a USB2 port.
This data will be fed to linux and then to epics.
Is anyone of you using epics with USB devices?
Any pointers? Does asyn interface with usb ports readily?
Emmanuel
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
RE: USB streaming device to linux/epics Pedersen, UK (Ulrik)
USB streaming device to linux/epics Emmanuel Mayssat
Prev: Comparing catime performance Matt Rippa
Next: RE: USB streaming device to linux/epics Pedersen, UK (Ulrik)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: USB streaming device to linux/epics Emmanuel Mayssat
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
