1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: USB streaming device to linux/epics
To: Emmanuel Mayssat <[email protected]>
Cc: epics <[email protected]>
Date: Fri, 09 Jan 2009 10:32:26 -0500
Emmanuel Mayssat wrote:
> Hello again,
> I am contemplating writing a low level linux driver to read a stream of
> data coming for custom made device and on a USB2 port.
> This data will be fed to linux and then to epics.
> Is anyone of you using epics with USB devices?
> Any pointers? Does asyn interface with usb ports readily?
> Regards,
> Emmanuel
Hi Emmanuel,
We used Opal Keely's USB-FPGA module (about $400) to bring data to
linux/epics through FPGA and USB port. The company provide a binary
library for Linux, but the source code is not open.  The USB
microcontroller on the module is Cypress's high speed USB controller
CY7C68013 (FX2) ($15).
There is an open source framework (xguff
*http://recycle.lbl.gov/~ldoolitt/xguff.html*) developed by Larry
Doolittle at LBL will do the work (hardware data -- FPGA -- high speed
USB -- Linux -- epics).  It can support USB 2.0 and has all the source
code (host-side code, FPGA and USB firmware design) open.  It supports
the FX2 chip. We are planning to use this in one of our power supply
controller.
Hope this helps.
Yuke Tian
NSLS-II Control Group
Brookhaven National Lab
USB streaming device to linux/epics Emmanuel Mayssat
Prev: Re: USB streaming device to linux/epics J. Lewis Muir
Next: Channel Access performance metrics & PLC reliability Dalesio, Leo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: USB streaming device to linux/epics Mark Rivers
Next: Comparing catime performance Matt Rippa
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
