1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: IOC can write but no longer read?!?
To: [email protected]
Date: Thu, 15 Jan 2009 13:56:45 -0800
Dear Tech-talk,
Happy New Year :)
Here is a curious problem: the IOC we have been using without a problem in the past all of a sudden will no longer read back correct values, but it can still write them.
A little background information to set the stage. The supply is a CAEN SY1527LC mainframe with four A1534P/N boards. The IOC was written by Ru Igarashi from the Canadian Light Source (http://www.aps.anl.gov/epics/modules/manufacturer.php#CAEN ) and we modified it a little for our purposes at BNL during the summer of 2006. No further modifications were made to the source code since then.
Three months ago we were using the IOC without any problems. Last week when I launched the IOC I noticed I could set parameters and turn on channels – verified this via the built-in telnet interface of the mainframe. However, I was no longer able to read back the channel parameters properly. There is no error message, it just reads 0 all the time. The PV which read the momentary voltage output always reads 0 now, similarly for the channel status PV and so on.
I did noticed with one PV it would retrieve the correct value eventually. The initial current limit is 100uA and the read back PV says as much. Then I set it to 50uA but read back 100uA – even after the scan period has long expired. Set it to 75uA and now I read back 50uA.
The trouble shooting I have done thus far is (all of which was unsuccessful):
re-compiled the IOC
turned off the firewall
verified the CAEN provided C wrapper library to which the IOC calls is the same as the backup version
I used the demo program CAEN provided with the C wrapper library to verify I can read out the channel parameters successfully with it – so I believe the mainframe is fine.
Right now I am at a loss as to what has changed. The only thing I can think of is we updated the system software via yum to the latest Scientific Linux 4.x.
However, the vlinac and another IOC are fine.
Any thoughts or suggestions would be greatly appreciated,
Bertrand
P.S. I hope this is a really trivial problem due to some simple misconfiguration I am not thinking of :)
Prev: Re: virtual linac with libstdc++.so.6 Andrew Johnson
Next: Re: Problems getting edm functional on NetBSD David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
