1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA Problem
To: [email protected]
Date: Tue, 20 Jan 2009 17:37:15 -0600
On Tuesday 20 January 2009 17:17:09 Szalata, Zenon M. wrote:
> I have a number of soft IOC's.  Each individually works fine.  I have
> recently noticed that after I start the second IOC, EDM can no longer
> establish "new" CA connections with the first IOC.  It does not matter
> which of my IOC's I start first and which second.  The end result is that
> starting the second IOC breaks the channel access to the first.  I
> suspected caRepeater, which I restarted.  This made no difference.
> These IOC's are built with epics R3.14.9, asyn R4.9, streamdevice R2-3 and
> a few other support modules.
Are these soft IOCs all running on the same server?  Is this server on
different subnet than your EDM client, so that on the client machine you have
to have EPICS_CA_ADDR_LIST set to the server's IP address to reach it?
If the answer to those questions is yes, change the EPICS_CA_ADDR_LIST entry
from the server's IP address to the broadcast address of the subnet that it
belongs to, because you've hit the classic Directed UDP distribution issue
which is arguably a bug in pretty much every single IP network stack in
existence.
If not, you'll need to tell us more about your settings.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
CA Problem Szalata, Zenon M.
Prev: EDM freezes Szalata, Zenon M.
Next: RE: CA Problem Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CA Problem Szalata, Zenon M.
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
