1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Multithreading in R3.14.9 - preemptive callbacks not working.
To: "'Douglas Morrison'" <[email protected]>, <[email protected]>
Date: Wed, 21 Jan 2009 08:33:52 -0700
Hello Doug,
I suspect that it will work as you were expecting in the first program if you add a ca_flush call after the ca_add_event call. Let me know if that doesn’t take care of it and I will have a closer look.
Jeff Hill
From: [email protected] [mailto:[email protected]] On Behalf Of Douglas Morrison
Sent: Tuesday, January 20, 2009 7:02 PM
To: [email protected]
Subject: Multithreading in R3.14.9 - preemptive callbacks not working.
Hello,
I am running EPICS R3.14.9 on a Solaris 10 machine, and am having difficulties implementing a multithreaded event monitoring application. The goal is for the main thread to open channel connections, and wait for user commands to perform other tasks. An auxiliary thread would be responsible for processing channel events as they occur.
I have read in the 3.14 users manual that when the context is created using ca_enable_preemptive_callback, the CA library will spawn auxiliary threads that will automatically execute event callbacks. I use the following code to open a channel and set a callback (error handling removed for brevity):
void connect_handler(struct connection_handler_args connect_args)
            // Handle connection events.
void event_handler(struct event_handler_args event_args)
            // Print data.
int main(…) {
    chid chId;
    int stat;
    stat = ca_context_create(ca_enable_preemptive_callback);
    stat= ca_create_channel(argv[1], connect_handler, argv[1], 49, &chId);
    // Give the connect request time to process
    ca_pend_event(0.05);
    stat=ca_add_event(DBR_DOUBLE, chId, event_handler, NULL, NULL);
    sleep(10.0);
Based on what I’ve read, I would expect that while the main thread is sleeping, the CA auxiliary threads would be finding events and executing the callback, however it never does (the actual database value is update at 2 Hz). Is my understanding or setup of the CA connections incorrect for this usage?
As a fix, I acquire the ca_context right after I create it, and attach an application thread to the context which is responsible for executing periodic polling (again, error checking removed for brevity):
struct ca_client_context* caContext = NULL;
void* dispatcher(void* ctx)
   stat = ca_attach_context(caContext);
   while(1) {
      ca_pend_event(0.0001);
      sleep(0.5);
   return NULL;
int main(…)
    caContext = ca_current_context();
    pthread_create(&dispatchThread, NULL, dispatcher, NULL);
    sleep(10.0);
Using this setup I successfully get callback events. Did I misunderstand the documentation when it said the CA Library would create its own event processing threads, and that the second method I emply is actually the correct method?
Final question: When using preemptive callbacks, performing a select on the file descriptors created by channel connections no longer see any change on the sockets. Why is this (what is the motivation)?
Any help would be greatly appreciated.
Douglas A. T. Morrison
Software Engineer
C.A.R.A - W. M. Keck Observatory
65-1120 Mamalahoa Hwy.
Kamuela, HI. 96743
Office: (808)881-3539
Cell: (808)937-0998
RE: Multithreading in R3.14.9 - preemptive callbacks not working. Douglas Morrison
Prev: caTools source Yuriy Gorbunov
Next: Re: EDM freezes Brian Bevins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Multithreading in R3.14.9 - preemptive callbacks not working. Douglas Morrison
Next: RE: Multithreading in R3.14.9 - preemptive callbacks not working. Douglas Morrison
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
