Hi Steve,
On Thursday 22 January 2009 14:27:44 Steve Kinder wrote:
> I have seen what may be a bug with vdct when using quoted strings in
> fields. This has occured when using these strings in the calc fields of
> scalcout records. As an example using calcs like A=6?0:dbl(AA["X ","Z"]).
> vdct saves this as field(CALC, "A=6?0:dbl(AA[\"X \",\"Z\"])"). Fine.
> However when running vdct again and loading these fields back in they all
> seem to be truncated after the first \.
> Not sure there will be an easy workaround this. I believe the quotes within
> the field are necessary. Just wanted to report it somewhere as it seems
> like a bug.
It looks like the scalcout record understands both single- and double-quoted
strings, so try using this for your expression instead:
A=6?0:dbl(AA['X ','Z'])
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
- Re: vdct problem with quoted strings Steve Kinder
- vdct problem with quoted strings Steve Kinder
RE: Very slow reconnection to medm after IOC reboot Mark Rivers
<2009>
2025
<2009>
2025
