1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Very slow reconnection to medm after IOC reboot
Cc: epics <[email protected]>
Date: Thu, 22 Jan 2009 15:46:56 -0600
On Thursday 22 January 2009 15:32:47 Mark Rivers wrote:
> I noticed that when I start win32-x86 IOCs built with 3.14.10 I get the
> following message just after iocInit:
> The CA server's beacon address list was empty after initialization?
> I do not get this message when running the identical IOC built with
> 3.14.8.2.
> Is this significant?  Why am I getting this message?
Highly, it means that the IOC is not sending out any CA beacons at all, which
explains why the clients are not reconnecting to it immediately.  Try setting
EPICS_CAS_BEACON_ADDR_LIST on the IOC to your 164.54.160.255 broadcast
address, although it should default to the value of EPICS_CA_ADDR_LIST if not
set so I don't understand why it's ignoring that (unless you have other env
settings for the IOC that you haven't told us about).
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
RE: Very slow reconnection to medm after IOC reboot Mark Rivers
Prev: RE: Very slow reconnection to medm after IOC reboot Mark Rivers
Next: RE: Very slow reconnection to medm after IOC reboot Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
