1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: SNCSEQ Path Problem
From: "Pawel Kowalski - BiRa Systems Inc." <[email protected]>
To: <[email protected]>
Date: Tue, 3 Feb 2009 10:53:50 -0700
Hello, I am totally new to epics and quite new to linux. It looks like after
much trouble I have finally been able to compile epics base on cygwin
running under windows xp. I am now trying to get the sample application
running from the "Epics Application Developer's Guide" in section 2. I have
made it down to section 2.2.4 where it asks me to set SNCSEQ. The problem is
I don't really know what to set this to. When I leave this commented out the
application compiles but doesn't run. I see that there is a sncExample.st
file under "myexampleApp/src" that makebaseApp.pl made. When I set this
variable to that location (epics_apps/myexampleApp) and uncomment it the
program fails to compile, the output is:
Pawel Kowalski@SKLED /epics_apps
$ make
make -C ./configure install
make[1]: Entering directory `/epics_apps/configure'
perl /epics/base/bin/cygwin-x86/convertRelease.pl checkRelease make -C
O.cygwin-x86 -f ../Makefile TOP=../.. T_A=cygwin-x86 install
make[2]: Entering directory `/epics_apps/configure/O.cygwin-x86'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `/epics_apps/configure/O.cygwin-x86'
make[1]: Leaving directory `/epics_apps/configure'
make -C ./myexampleApp install
make[1]: Entering directory `/epics_apps/myexampleApp'
make -C ./src install
make[2]: Entering directory `/epics_apps/myexampleApp/src'
make -C O.cygwin-x86 -f ../Makefile TOP=../../.. T_A=cygwin-x86 install
make[3]: Entering directory `/epics_apps/myexampleApp/src/O.cygwin-x86'
make[3]: *** No rule to make target `sncExample.o', needed by
`myexampleSupport.
dll'. Stop.
make[3]: Leaving directory `/epics_apps/myexampleApp/src/O.cygwin-x86'
make[2]: *** [install.cygwin-x86] Error 2
make[2]: Leaving directory `/epics_apps/myexampleApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/epics_apps/myexampleApp'
make: *** [myexampleApp.install] Error 2
Any help would be greatly appreciated.
Re: SNCSEQ Path Problem Tim Mooney
Prev: SNCSEQ Path Problems Pawel Kowalski - BiRa Systems Inc.
Next: Multiple power supplies on one IOC Bertrand H.J. Biritz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: SNCSEQ Path Problem Tim Mooney
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
