1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Console access and managing soft IOCs
To: "Pearson, MR (Matthew)" <[email protected]>
Cc: [email protected]
Date: Thu, 12 Feb 2009 07:01:24 -0800
I use procServ just as Mark Rivers does. I make shell aliases to: (a) invoke the initial procServ session; (b) connect to a session in progress. Ralph Lange kindly added the '-allow' option for non-local telnet access. So if you don't need the other features he mentions, procServ alone is a minimal but sufficient solution for a small installation and provides a 'common interface' if you have it invoke the telnet for the VME IOCs (yes, telnet to telnet).
At 3:39 PM +0100 2009/02/12, Ralph Lange wrote:
provServ runs the IOC and provides access through local telnet.
conserver provides the common interface to both soft and VME IOCs, handles user authentification, read-only vs. read/write access, time stamped logging, playback of recent console output (without screwing up the log file), and more.
At 1:45 PM +0000 2009/02/12, Pearson, MR (Matthew) wrote:
Thanks. Yes, I'm not sure we would need to use conserver if we had
procServ. I get the impression that the only reason other sites had the
IOC->procServ->conserver layering was to preserve to conserver
interface.
Cheers,
Matthew
 -----Original Message-----
 Sent: 12 February 2009 12:59
 To: Pearson, MR (Matthew); [email protected]
 We recently started using procServ for both our VME IOCs and
 soft IOCs.  It's great, since multiple users can be seeing
 the console at once, and logging is done.  The VME IOCs are
 connected to terminal servers, so the procServ process for
 > them is a telnet session to the particular terminal server port.
Console access and managing soft IOCs Pearson, MR (Matthew)
RE: Console access and managing soft IOCs Mark Rivers
RE: Console access and managing soft IOCs Pearson, MR (Matthew)
Prev: Re: Console access and managing soft IOCs Ralph Lange
Next: Re: Console access and managing soft IOCs Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: CA Server queue depth Bruno Coudoin
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
