1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: soft device for ai record works as sscanf.
To: [email protected]
Cc: [email protected]
Date: Tue, 24 Feb 2009 22:36:59 +0900
Thanks Tim and Ben,
Tim Mooney wrote:
> Noboru,
> Similar:
> The sCalcout record (in the synApps calc module) does this.
> See http://www.aps.anl.gov/bcda/synApps/calc/calc.html
I will check it, tomorrow.
Benjamin Franksen wrote:
> On Tuesday 24 February 2009 07:50, Noboru Yamamoto wrote:
>> I'm looking for a soft device support for ai which convert string data
>> from INPUT link to analogue value, like sscanf in C language.
>> Does anyone have this or similar device support ?
> Have you looked at StreamDevice?
If I needed to access HW, I woudl use StreamDevice or asynDriver.
In this case, we already have device support (and stringin records)
which takes data from HW. So now our user want convert this string into
number in EPICS database.
Does StreamDevice work with stringin record in this way?
> http://epics.web.psi.ch/software/streamdevice/
> Cheers
> Ben
Thank you very much again for your help.
Noboru
Re: soft device for ai record works as sscanf. Dirk Zimoch
soft device for ai record works as sscanf. Noboru Yamamoto
Re: soft device for ai record works as sscanf. Benjamin Franksen
Prev: Re: can't output strings array with gensub Matthieu Bec
Next: Re: can't output strings array with gensub Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: soft device for ai record works as sscanf. Benjamin Franksen
Next: Re: soft device for ai record works as sscanf. Dirk Zimoch
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
