1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Useless error messages in EPICS
To: "'Dirk Zimoch'" <[email protected]>, "'Martin L. Smith'" <[email protected]>
Cc: "'tech-talk'" <[email protected]>
Date: Mon, 2 Mar 2009 13:32:10 -0700
Hi Dirk,
The relevant mantis issue is in fact entry 329.
> I can try:
> - pChan->getPV()->pPVI->deleteSignal ();
> Jeff, do you think that will do?
That should take care of the problem.
Jeff
> -----Original Message-----
> From: Dirk Zimoch [mailto:[email protected]]
> Sent: Monday, March 02, 2009 8:48 AM
> To: Martin L. Smith; Jeff Hill
> Cc: tech-talk
> Subject: Re: Useless error messages in EPICS
> Hi Martin,
> Thanks for the hint.
> I still use R3.14.8.2. The code looks a bit different:
>      if ( status != S_cas_success ) {
>          this->chanTable.remove ( *pChan->pChanI );
>          this->chanList.remove ( *pChan->pChanI );
>          pChan->pChanI->uninstallFromPV ( this->eventSys );
>          delete pChan->pChanI;
>      return status;
> I can try:
> Dirk
> Martin L. Smith wrote:
> > Hi Dirk,
> > I ran into this same problem back in January and it turns out that this
> > is Mantis entry 329. Jeff Hill made a fix for this; from a previous
> > email that I still have:
> > diff -u -b -w -b -r1.92.2.16 casStrmClient.cc
> > --- casStrmClient.cc 21 Oct 2008 20:50:26 -0000 1.92.2.16
> > +++ casStrmClient.cc 8 Jan 2009 22:13:09 -0000
> > @@ -1413,9 +1413,7 @@
> > - casPVI * pPVI = pChan->getPV()->pPVI;
> > - pPVI->deleteSignal ();
> > return status;
> > After Janet Anderson rebuilt the GW using this fix, which should be
> > committed to the repository, I have not had this problem since.
> > Marty
> > Dirk Zimoch wrote:
> >> Hi all,
> >> This night, I had a problem with a CA gateway. The log file contained
> >> the following error messages:
> >>> epicsMutex pthread_mutex_lock failed: error Invalid argument
> >>> Mar 02 00:04:46 !!! Errlog message received (message is above)
> >>> fatal error: epicsMutexOsdLock
> >> I found these messages not very helpful because they do not tell me
> >> where the error occurred and why the argument is invalid. This makes
> >> it impossible to debug the problem.
> >> Unfortunately, this is often the case with EPICS errors. I observe
> >> three problems with locations of errors:
> >> 1. The error message does not give any hint of the location at all.
> >> 2. The reported location is inside a (EPICS) system function or a
> >> macro, but the  caller who actually caused the error is not reported.
> >> 3. The reported location is inside the source code of a file parser
> >> but the error location in the faulty file is not reported.
> >> In this case, we have situation 2. The problem occurred in
> >> epicsMutexOsdLock(), but this function is called at so many places in
> >> EPICS that it's impossible to track down the origin of the fault.
> >> When looking into epicsMutexOsdLock(), I found that the calling thread
> >> is suspended via a call to cantProceed() when an error happens. In my
> >> opinion, this is as well not very helpful because the calling function
> >> does not get any indication of the failure and thus cannot print a
> >> proper error message.
> >> In my opinion, cantProceed() does more harm than good as long as it is
> >> not able to provide useful debug information (at least a stack trace)
> >> -- which is probably hard to do in a portable way. I think, a call to
> >> abort() would be more helpful as it produces a process dump (at least
> >> on Unix systems) which can be analyzed.
> >> Generally, error handling should not be part of the low-level
> >> functions. These functions do not have any application knowledge and
> >> thus cannot decide if suspending the thread, terminating the program,
> >> printing an error message or continuing normally is the "correct"
> >> behavior. Instead, low-level functions should only report errors (by
> >> or exceptions or return values -- I am not religious in this matter)
> >> and leave the choice of the correct response to the caller.
> >> In this case, the gateway (maybe the CAS library) stopped accepting
> >> new clients which made it effectively useless. On the other hand, it
> >> did not terminate. Thus any mechanism to restart the gateway on
> >> failure does not work, too. I do not consider this a "useful" behavior.
> >> It may be a goal of the next codathlon to improve the error messages
> >> provided by EPICS.
> >> Dirk
> Dr. Dirk Zimoch
> Paul Scherrer Institut, WBGB/006
> 5232 Villigen PSI, Switzerland
> Phone +41 56 310 5182
Useless error messages in EPICS Dirk Zimoch
Re: Useless error messages in EPICS Martin L. Smith
Re: Useless error messages in EPICS Dirk Zimoch
Prev: Re: Useless error messages in EPICS Andrew Johnson
Next: Where to find CA.DLL version 3.14.8? Richard Swent
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Useless error messages in EPICS Dirk Zimoch
Next: Re: Useless error messages in EPICS Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
