1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EDM dynamic precision update, help
To: [email protected]
Date: Tue, 3 Mar 2009 12:38:45 -0800 (PST)
Hello,
I have a database running on an IOC running an ai record named '$(SubSys):$(Device):Read'. I display the value in the record using EDM with the Text Monitor widget (I have tried other widgets but they all have the same issue.) The precision is set to get the precision from the database, which it does.
In the database I have ao records that push different precision values into $(SubSys):$(Device):Read.PREC dynamically. I have checked and the values are indeed being placed into the PREC field correctly.
The problem is EDM doesn't redraw the widget to incorporate the changed PREC values. I tried putting Text Monitor widget on a different screen, opened by a related display button, but even when the new window is opened; it doesn't redraw the Text Monitor with the new precision (VAL is updated correctly.) If I close EDM completely and restart it, the new precision values are reflected correctly. This leads me to believe that EDM assumes PREC fields to be constant upon initialization, is this correct? If so, is there any way to change this?
If anyone has encountered this problem or knows a work around I would appreciate the help.
Mathew Hicks
Re: EDM dynamic precision update, help Andrew Johnson
Prev: Channel Archiver 64-bit build Glen White
Next: Variable size frame Bruno Coudoin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EDM dynamic precision update, help Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
