1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Looking for feedback on what epics users require
To: "Pawel Kowalski - BiRa Systems Inc." <[email protected]>
Cc: [email protected]
Date: Tue, 10 Mar 2009 07:58:21 -0700
Here at SLAC we would most likely use EDM as our client interface.
In this case, we simply require access to the PVs that your IOC would provide.
We also, require the ability to modify anything in the source code of your EPICS IOC for customization.
Will your solution be fully open source such as your vxWorks driver code?
Ernest
SLAC Control Systems
Pawel Kowalski - BiRa Systems Inc. wrote:
Hello,
My company is researching providing an epics IOC with some of our power supplies. I would like to get some feedback from the epics community on what exactly would be required. First let me start off by saying that epics is still a new area for me so hopefully these questions aren't dumb, we are still in the early research stages on this. What we would like to do is provide a system with each device that will host an EPICS IOC. This will be a vxWorks based system running epics base 3.14. This system will communicate with our device using ethernet and convert standard UDP commands that our devices work on to process variables. So for example our clients would now have a process variable they could use to monitor or set the voltage of a power supply (IE: powersys:voltage). For the client side we would like to develop a LabVIEW interface, we would most likely not be developing a custom C/C++ application for the client. Would this be adequate for most epics users or would more be required to integrate this into an existing epics network? Would people use the LabVIEW client we develop or do most labs use their own custom software to control/monitor epics enabled equipment? Any feedback from the community would be greatly appreciated, thank you.
RE: Looking for feedback on what epics users require Pawel Kowalski - BiRa Systems Inc.
Prev: Looking for feedback on what epics users require Pawel Kowalski - BiRa Systems Inc.
Next: Re: Looking for feedback on what epics users require Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: RE: Looking for feedback on what epics users require Pawel Kowalski - BiRa Systems Inc.
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
