Thanks to all your replies. I'd reply once here.
> Was the final position reached? Or did the motor stop just outside the
deadband RDBD?
Yes. The actual position is reached.
> Are you able to do another move after you 'prod' the record?
Yes. It can still drive the motor to the correct position.
> Does this happen every time on the same axes, or intermittently?
Every time with the same axes.
>To help diagnose this it might be worth turning on Asyn tracing for
that
>axis, like:
>asynSetTraceIOMask("PORTNAME",{card_no},255)
>asynSetTraceMask("PORTNAME",{card_no},255)
I have redirect the output to file. From there I can say the
communication is correct.
MS and TP command return correct information.
>Might be worth updating to asynMotor from 6-4-2 as well.
This is also what Ron has suggested.
I will try first use the new release. But because the way how drivers
are used in SLS,
it requires some time to setup. I will get back to you then.
Thanks all.
Xiaoqiang
- RE: MM4000 asynMotor problem Wang Xiaoqiang
- MM4000 asynMotor problem Wang Xiaoqiang
- RE: MM4000 asynMotor problem Pearson, MR (Matthew)
<2009>
2025
<2009>
2025
