1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Help building EPICS 3.14.9 for RTEMS
To: Sue Witherspoon <[email protected]>
Cc: Tech-talk <[email protected]>
Date: Mon, 16 Mar 2009 16:51:36 -0700
BTW:
There was a significant bug
https://www.rtems.org/bugzilla/show_bug.cgi?id=1385
in RTEMS 4.9.1 affecting i386 and m68k
(and maybe others but PPCs using the shared exception framework
[mvme2100, mvme5500, mvme3100, ...] are OK)
you want to upgrade to 4.9.2
-- Till
Sue Witherspoon wrote:
Thanks Eric and Till for the prompt reply. I added
 unexport GCC_EXEC_PREFIX  in CONFIG_SITE.Common.RTEMS
That works!
until I get to osdInterrupt.c.   What's up with rtems_unsigned32?
Thanks in advance,
Sue
/usr/csite/pubtools/rtems/4.9.1/bin/i386-rtems4.9-gcc --pipe -B/usr/csite/pubtools/rtems/4.9.1/i386-rtems4.9/pc386/lib/ -specs bsp_specs -qrtems -fasm -c -mtune=i386 -ansi -O2 -g -g -Wall -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/RTEMS -I../../../include ../../../src/libCom/osi/os/RTEMS/osdInterrupt.c ../../../src/libCom/osi/os/RTEMS/osdInterrupt.c: In function 'InterruptContextMessageDaemon': ../../../src/libCom/osi/os/RTEMS/osdInterrupt.c:68: error: 'rtems_unsigned32' undeclared (first use in this function) ../../../src/libCom/osi/os/RTEMS/osdInterrupt.c:68: error: (Each undeclared identifier is reported only once ../../../src/libCom/osi/os/RTEMS/osdInterrupt.c:68: error: for each function it appears in.) ../../../src/libCom/osi/os/RTEMS/osdInterrupt.c:68: error: expected ';' before 'size' ../../../src/libCom/osi/os/RTEMS/osdInterrupt.c:83: error: 'size' undeclared (first use in this function)
gmake[3]: *** [osdInterrupt.o] Error 1
RE: Help building EPICS 3.14.9 for RTEMS Sue Witherspoon
Prev: Re: Help building EPICS 3.14.9 for RTEMS Till Straumann
Next: 答复: how to change the MEAN without reboot IOC? 汪启胜
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Relational Database Poll Mike Forster
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
