Hi Oleg,
On Monday 16 March 2009 16:43:26 Oleg Makarov wrote:
> It is strange though that it does not work without explicit pvFlush()
> calls. If "+a" option is not set for snc compiler, one would expect
> synchronous IO to be performed.
I suspect part of the problem might be that you're calling epicsThreadSleep()
inside the action statements, which completely freezes the sequence program
during that delay period. This almost always turns out to be the wrong thing
to do since the sequence program can't break out of that delay if something
unexpected happens. You should instead call the delay() function inside a
when() statement, which also permits the sequencer to perform other actions
while it's waiting. I would recommend changing your program to look more
like this instead (not tested), which might help:
ss main {
state init {
when (pvConnectCount() == pvChannelCount()) {
} state connected
state connected {
when (1)
strcpy(str_cmd, "I522");
pvPut(str_cmd);
pvFlush();
} state action522
state action522 {
when (delay(1.0)) {
pvGet(str_rsp);
} state getting
state getting {
when (delay(1.0)) {
printf("str_rsp = %s \n", str_rsp);
strcpy(str_cmd, "I521");
pvPut(str_cmd);
pvFlush();
} state action521
state action521 {
when (pvConnectCount() != pvChannelCount()) {
} state init
when (delay(1.0)) {
} state connected
Note that you can easily add the ability to react to channel disconnection in
the action522 and getting states if you wish.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
- weird behaviour of SNL test program running on Soft IOC on LINUX Oleg Makarov
- Re: weird behaviour of SNL test program running on Soft IOC on LINUX J. Lewis Muir
- Re: weird behaviour of SNL test program running on Soft IOC on LINUX Oleg Makarov
<2009>
2025
Re: weird behaviour of SNL test program running on Soft IOC on LINUX Pete Jemian
<2009>
2025
