1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Alarm Limits
Date: Thu, 19 Mar 2009 11:10:08 +0000 (GMT)
Can one use the output of a calc or a calcout routine to set values for HIHI, HIGH,
LOW, and LOLO?  When I load my database, I always get errors in these lines.  Is
there some sort of special incantation that I must do?
Here's what I have.  I've used camonitor to check that all of the records leading
up to and including the calc records work as expected.  For the calcout routines,
I have a value between 0<= VAL <=1 for ILimMajor and ILimMinor.  The calcout
records appear to do what I want them to do:
record(calcout, "$(user):calcQ1I_HiHi") {
	field(DESC, "Q1 I Max Major limit")
	field(PREC, "3")
	field(INPA, "$(user):Q1SetCurrent.VAL  NPP NMS")
	field(INPB, "$(user):ILimMajor.VAL  NPP NMS")
	field(CALC, "A+(A*B)")
record(calcout, "$(user):calcQ1I_High") {
	field(DESC, "Q1 I Max Minor limit")
	field(PREC, "3")
	field(INPB, "$(user):ILimMinor.VAL  NPP NMS")
	field(CALC, "A+A*B")
record(calcout, "$(user):calcQ1I_Low") {
	field(DESC, "Q1 I Min Minor limit")
	field(PREC, "3")
	field(CALC, "A-A*B")
record(calcout, "$(user):calcQ1I_LoLo") {
	field(DESC, "Q1 I Min Major limit")
	field(PREC, "3")
record(ai, "$(user):Q1ReadCurrent") {
	field(DESC, "Q1 Magnet Readback Current")
	field(PREC, "3")
	field(INP,  "$(user):rampQ1Current.VAL NPP NMS")
	field(EGUF, "10")
	field(EGU,  "A")
	field(HOPR, "2000")
	field(LOPR, "0")
	field(HIHI, "$(user):calcQ1I_HiHi.VAL")
	field(HIGH, "$(user):calcQ1I_High.VAL")
	field(LOW,  "$(user):calcQ1I_Low.VAL")
	field(LOLO, "$(user):calcQ1I_LoLo.VAL")
	field(HHSV, "MAJOR")
	field(HSV,  "MINOR")
	field(LSV,  "MINOR")
	field(LLSV, "MAJOR")
	field(FLNK, "$(user):Q1RampCurrent.PROC")
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039         office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
RE: Alarm Limits Owens, PH (Peter)
RE: Alarm Limits Mark Rivers
Prev: Re: epics GUIs (update) Noboru Yamamoto
Next: Re: Starting multiple SNL programs Martin L. Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: RTEMS-mvme5500 BSP update Kate Feng
Next: RE: Alarm Limits Owens, PH (Peter)
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
