1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RTEMS-mvme5500 BSP update
To: Joel Sherrill <[email protected]>
Cc: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 19 Mar 2009 14:38:13 -0400
Sorry.  Here is the attachment.  Kate
Kate Feng wrote:
Joel Sherrill wrote:
Any chance of getting a patch to apply to the
RTEMS source base?
The attached mvme5500-patch.tar.gz  contains two files :
mvme5500-rtems4.8.0-2009319.diff
mvme5500-rtems4.9.1-20090319.diff
I tried to file a PR, but it seems that there are some problems
with the bug tracking system : bugzilla.  I could not even view
https://www.rtems.org/bugzilla/show_bug.cgi?id=1385
It was OK last week, though.
Kate
--joel sherrill
RTEMS
Kate Feng wrote:
The stable version of RTEMS-mvme5500 BSP is posted at
http://www.nsls.bnl.gov/facility/expsys/software/EPICS/
The "RTEMS-mvme5500 BSP v1.4.9.1", was tested
under RTEMS 4.9.1, and the "RTEMS-mvme5500 BSP v1.4.8.0"
was tested under RTEMS 4.8.0..
The highlights of the change are :
1)  Use the GT_GPP_Value register (0xf104) instead of the
GT_GPP_Interrupt_Cause register (0xf108) to monitor the cause
of the level sensitive interrupts. See irq/BSP_irq.c.
This is an unique solution which solves part of the bugs in
the BSP, which especially affects the 1GHz network driver.
2) There is no change in the 100 MHz network driver. Thus,
its performance stays the same.  Some bugs were fixed in the
1GHz network drivers (e.g. if_wm.c).
3)Enable "PCI Read Agressive Prefetch", "PCI Read Line Agressive Prefetch", and "PCI Read Multiple Agressive Prefetch" to improve the performance of the PCI based applications (e.g. 1GHz network driver). See pci/pci_interface.c.
However, performance is driven by applications.
There is no known bug at this point.  Any feedback which is related to
the RTEMS-mvme5500 BSP would be highly appreciated.
Hope this helps,
Kate
rtems-users mailing list
[email protected]
http://rtems.rtems.org/mailman/listinfo/rtems-users
Attachment: mvme5500-patch.tar.gz
Description: GNU Zip compressed data
RTEMS-mvme5500 BSP update Kate Feng
Re: RTEMS-mvme5500 BSP update Joel Sherrill
Re: RTEMS-mvme5500 BSP update Kate Feng
Prev: Re: RTEMS-mvme5500 BSP update Kate Feng
Next: Re: RTEMS-mvme5500 BSP update Joel Sherrill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
