1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Smoothing and alarm filtering on the analog input record - a proposal
To: <[email protected]>
Date: Mon, 30 Mar 2009 16:43:07 -0400
DESY would like to see the following changes:
SMOO applies to all values returned from device support - weather or not they need to be converted. This should have no impact - as device support that returns engineering numbers likely does not have SMOO set to anything. Same thing for returning values from database links that are inputs. Any objections?
Add the following fields
MSEV - measured alarm severity
MSTA - measured alarm status
CFIL - number of scans this status must be true before it is applied
ACNT - number of scans this status and alarm severity have been detected
Two questions: does the count get reset every time the alarm condition changes? Does it need to be more intelligent?
We are accepting input for 24 hours.
Bob
Re: Smoothing and alarm filtering on the analog input record - a proposal Kasemir, Kay
Re: Smoothing and alarm filtering on the analog input record - a proposal Dirk Zimoch
Prev: using sca from vba in excel Geoff Savage
Next: Re: Smoothing and alarm filtering on the analog input record - a proposal Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
