1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: problem when running Channel Archiver
To: tech-talk <[email protected]>
Date: Tue, 7 Apr 2009 15:46:17 +0800 (CST)
Dear all,
  I have successfully installed Channel Archiver and base3.14.9-pre1 on Red Hat Linux WS4 . But ther are following error when I run "ArchiveEngine" :
   $ArchiverEngine
   $ArchiveEngine:error while loading shared libraries:libxerces-c.so.24:can't open shared object file:No such file or directory
While the file "libxerces-c.so.24" in /usr/local/lib,  I rebuild the Channel Archiver setting LD_LIBRARY_PATH=/usr/local/lib:/home/fel/psm6003/extensions/lib/linux-x86
but it comes the same erro.
Best regards,
Demin Zhang
网易邮箱,中国第一大电子邮件服务商
Re: problem when running Channel Archiver Dirk Zimoch
Prev: Re: longout record issue Dirk Zimoch
Next: Re: problem when running Channel Archiver Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: longout record issue Emmanuel Mayssat
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
