1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: alarm acknowledgement
Date: Thu, 9 Apr 2009 17:17:01 +1000
Hi All
Perhaps someone can point to me to the doco that describes how an acknowledgement can be sent to an alarmed record?
I see that there is a field ACKT that if set to YES means that an alarm must be acknowledged and is latched until it is, and I see reference to Channel Access providing a method to do this but I can’t find the details. Is there any way (other than installing the ALH alarm handler gui) that I can acknowledge (and presumable reset) a transient alarm in a record? I was hoping for something as simple as a caput….
Thanks in advance.
Dr. Terry Cornall | Senior Controls  Engineer | Australian Synchrotron
p: (03) 8540 4280 | f: (03) 8540 4200
[email protected] | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Re: alarm acknowledgement Marty Kraimer
Prev: Re: gensub constant char input parameter Maren Purves
Next: EpicsEventShow Martin Konrad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: alarm acknowledgement Marty Kraimer
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
