1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: NTPTimeSync timeout messages on VxWorks with EPICS 3.14.10
To: [email protected]
Date: Fri, 17 Apr 2009 18:01:17 -0400
I upgraded two VME IOCs to EPICS 3.14.10 and now am getting console
messages like the following:
  NTPTimeSync: NTP requests failing - S_sntpcLib_TIMEOUT
  NTPTimeSync: Sync recovered.
These messages seem to appear approximately every 5-10 minutes.
What's causing this?
Here's what NTPTime_Report says if it's helpful:
ioc1> NTPTime_Report 1
NTP driver is synchronized with server
Syncronization interval = 60.0 seconds
Last synchronized at 2009-04-17 16:38:03.383080
OS tick rate = 60 Hz (nominal)
Measured tick rate = 60.000 Hz
NTP Server = 164.54.200.10
value = 0 = 0x0
The other IOC has a similar report:
ioc2> NTPTime_Report 1
Last synchronized at 2009-04-17 16:37:59.125608
Measured tick rate = 59.999 Hz
value = 0 = 0x0
IOC info:
* VME processor module: Motorola MVME-5100 (vxWorks-ppc604_long)
  - CPU: MPC 750
  - Memory: 512 MB
* OS: VxWorks 5.4.2
* Kernel: WIND 2.5
* BSP: mv5100-asd9
* Build toolchain: Tornado 2.0.2
* EPICS 3.14.10 (+ Known Problems patches)
* synApps 5.4.1
Lewis
J. Lewis Muir
Software Engineer
CARS/IMCA-CAT
Re: NTPTimeSync timeout messages on VxWorks with EPICS 3.14.10 Andrew Johnson
Prev: Re: ca_put with non base type John Hammonds
Next: Re: ca_put with non base type Bruno Coudoin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: ca_put with non base type Bruno Coudoin
Next: Re: NTPTimeSync timeout messages on VxWorks with EPICS 3.14.10 Andrew Johnson
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
