1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Winsock error10004
To: "'Mark Clift'" <[email protected]>, <[email protected]>
Date: Fri, 24 Apr 2009 09:42:06 -0600
Ø  Strangely, the ioc's that build under areaDetector 1-4 using win32-x86,
Ø  do not have this error on exit and run fine.
One possible difference could be systems with and without SMP (multi-core cpu or not). Alternatively, statically built or not might change the order of process rundown as executed by windows (i.e. threads stopped first versus shareable libraries unmapped from memory first).
Jeff
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Clift
Sent: Friday, April 24, 2009 4:55 AM
To: [email protected] ([email protected])
Subject: Winsock error10004
Hi all,
I'm building a basic IOC under windows XP by doing the following:
makeBaseApp.pl -t ioc <name>
makeBaseApp.pl -i -t ioc <name>
Then I build the ioc, and run it without databases.   The IOC runs without any initialisation errors.  The EPICS version is 3.14.10, and the compiler is Visual C++ Express 2005.  The EPICS build system is set to build statically.
Upon exit I get the following errors
CAS: Client accept error was "WINSOCK Error 10004"
CAS: UDP recv error (errno=WINSOCK Error 10004)
..\online_notify.c: CA beacon routing (connect to "10.123.255.255:5065") error w
as "WINSOCK Error 10093"
or
CA cast server: Unable to fetch N characters pending
Strangely, the ioc's that build under areaDetector 1-4 using win32-x86, do not have this error on exit and run fine.
Has anybody had this error ?  Why is the IOC expecting a response to a broadcast like this ?  Does anyone know how to fix  ?
Thanks heaps,
Mark Clift.
This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Re: Winsock error10004 J. Lewis Muir
Winsock error10004 Mark Clift
Prev: RE: Winsock errors Jeff Hill
Next: Re: Winsock error10004 J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Winsock error10004 Mark Clift
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
