I would like to save the values of a set of PVs (once per scan). I understand that [extraPV] is the relevant section of saveData.req to use. Further, I would like to save this same set of PVs for multiple independant instances of the sscan record running on different IOCs. (This set of PVs set would provide useful information on beamline and storage ring state.)
It would be good to avoid maintaining this set of PVs in two or more files. In the [extraPV] section of the saveData.req file, is it possible to reference another file (for single point of maintenance)? (I noticed that autosave req files support this syntax).
For example,
In saveData.req on IOC #1:
[extraPV]
file common_pvs.req
In saveData.req on IOC #2:
[extraPV]
file common_pvs.req
In separate file common_pvs.req:
# List of PVs to save once per scan
SOME:PV1
SOME:PV2
SOME:PV3
Is this or a similar syntax available?
Thanks in advance,
Dr Mark Bennett
Principal Controls Engineer
Australian Synchrotron
<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
- Re: Can the saveData config file referencence another file? Tim Mooney
RE: Process ordering in CA and asyn Jeff Hill
RE: Process ordering in CA and asyn Rees, NP (Nick)
<2009>
RE: Process ordering in CA and asyn Mark Rivers
<2009>
