1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: List of all server on an Epics network
To: [email protected]
Date: Tue, 26 May 2009 11:15:39 +0200
Hello Bruno,
as Channel Access is based on the PV name as unique identifier and quite completely hides distribution of PVs onto multiple servers, you will have to peek into the CA internals to find out.
Try the "casw" commandline utility with a high interest level. It will print all incoming CA beacons, which contain host and port of the CA server sending the beacon. Let it run for a while and filter the output: there's your list.
Note that, even as you know the server names, you can't "talk" to them directly through CA, unless your conventions enforce PVs with well-known names that every server in your system has to serve.
The Channel Access manuals will have more details on casw.
Good luck!
Ralph
On 25.05.2009 23:33 Bruno Coudoin wrote:
Is there a way to get the list of all the participants on an epics
network, especially the servers.
The use case is that I would like to be able to 'talk' to each of the
servers of my Epics network but how to know who is participating?
Bruno.
List of all server on an Epics network Bruno Coudoin
Prev: List of all server on an Epics network Bruno Coudoin
Next: Re: How to use process variable Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: List of all server on an Epics network Jeff Hill
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
