(copy of a message sent to Andrew last week)
I am testing an API which uses CA.pm for Perl procedures. My
specification says the procedure should abort when it loses
any CA connections. So I've started a soft IOC, started this test
procedure, and then stop the soft IOC when it tells me to. It sleeps
for a minute to allow CA to really disconnect (and there is a message)
but it never gets to the callback routine. (Actually, it gets there
once during channel creation - but not when the channel really
connects.) Am I doing something wrong here?
(This is a simplified version which cuts out anything not essential to
this test. I was hoping I'd get it to work and then be able to fix the
version in my API.)
Thanks.
Pam.
#!/bin/perl -w
# File: CA_test_subsequent_disconnect.pl
# Author: Pam Gurd
# Date: May 19, 2009
# script to test the connectPVs routine in CPP.pm
# CVS $Revision: $
# $Date: $
# $Author: $
# History:
# $Log: $
use lib '/usr1/local/epics/release/R3.14.10/base/lib/perl';
use CA;
sub INT_handler (;$);
our $startupflag = 1;
my @message_log = ();
my $no_status=0;
my $channel = CA->new("TEST:DEV1:CUR", &connectionCallback);
$SIG{'INT'} = 'INT_handler';
$SIG{__DIE__} = 'INT_handler';
CA->pend_io(3);
print "testing connection for TEST:DEV1:CUR\n";
die "TEST:DEV1:CUR is not connected.\n"
unless $channel->is_connected;
print "TEST:DEV1:CUR is connected.\n";
CA->pend_event(1);
$startupflag = 0;
printf("Stop the soft IOC and then press Enter ");
my $filename = <>;
printf("Wait 1 minute for EPICS disconnect\n");
sleep 60;
CA->pend_io(1);
CA->pend_event(1);
printf "3...";
sleep 1;
printf "2...";
sleep 1;
printf "1...";
printf "\nTest failed!\n";
sub INT_handler (;$) {
my ($message) = @_;
if ($message) {
print $message;
exit 1;
exit;
sub connectionCallback ($$) {
my ($chan, $connectionStatus) = @_;
if ($startupflag) {
return;
print "connection callback!";
if ($connectionStatus) {
print " status=$connectionStatus\n";
} else {
print " undef status\n";
INT_handler(" error: $chan->name!\n");
abortProcedure ();
- Re: CA.pm Andrew Johnson
Re: R3.14.9 access security and "no read access" w/caget Steven M. Hartman
Re: How to use process variable Mauro Giacchini
<2009>
Re: user-supplied functions Benjamin Franksen
<2009>
