1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: subArray processing
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Thu, 04 Jun 2009 08:37:12 +0200
Hi Lewis,
J. Lewis Muir wrote:
> On 6/3/09 8:23 AM, Hinko Kocevar wrote:
>>>> Hello,
>>>> I'm trying to use subArray record type to display each array element at
>>>> index 0 .. n (n == 10; my case) in a separate PV.
>>> For your subArray records, use . . .
>>>   field(MALM,"16") # number of elements of the waveform input
>>>   field(NELM,"1")  # number elements for desired subArray
>>> The subArray needs to allocate enough storage for MALM elements to  hold
>>> the whole INP waveform, but you only want NELM elements for the subArray
>>> itself.
>> If I change subArray records the way you described it does not change
>> the output of the monitor to display only one value. The output is the
>> same as in the case I've described in previous mail (not desired to have
>> trailing zeros).
> Hi, Hinko.
> I agree with Steven's advice that you should use MALM=16 for your
> subArray records.
> What version of EPICS are you using?  There is a known problem with the
> subArray record before EPICS 3.14.10.  Could you check the value of
> "$(DEVICE)B.INDX" during your test?  Has it been set to 0 even though
> you specified a value of 1?  If so, you may be running into the problem
> reported in the following Tech-Talk message:
I'm using EPICS 3.4.10 version.
The properties for LIBERA01:SA:B is shown below:
epics> dbpr LIBERA01:SA:B
ASG:                BUSY: 0             DESC:               DISA: 0
DISP: 0             DISV: 1             INDX: 1             NAME:
LIBERA01:SA:B
NELM: 1             NORD: 1             SEVR: NO_ALARM      STAT:
NO_ALARM
TPRO: 0             VAL: (nil)
I also looked at the other LIBERA01:SA:C, LIBERA01:SA:D, .. and the INDX
value is not 0 - for c it is 2, for D it is 3, .. This seems OK.
epics> dbpr LIBERA01:SA:C
DISP: 0             DISV: 1             INDX: 2             NAME:
LIBERA01:SA:C
NO_ALARM
TPRO: 0             VAL: (nil)
Hinko
Hinko Kocevar
Technical support engineer
Instrumentation Technologies
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
subArray processing Hinko Kocevar
Re: subArray processing Steven M. Hartman
Re: subArray processing Hinko Kocevar
Re: subArray processing J. Lewis Muir
Prev: Re: subArray processing Hinko Kocevar
Next: catools for cross compiled target Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: subArray processing J. Lewis Muir
Next: Re: subArray processing Carl Lionberger
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
