1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stanford Research PS310 Power Supply
To: EPICS tech-talk <[email protected]>
Date: Mon, 08 Jun 2009 14:55:13 -0500
Joe Sullivan wrote:
James Stevens wrote:
I would like to know if anyone in the Epics
community has  written a GPIB device driver
for the Stanford Research Systems, Inc. Model
PS310 high voltage power supply...
http://www.teknetelectronics.com/Search.asp?p_ID=15873&pDo=DETAIL
Regards--Jim S.
Jim,
There is "unreleased" support for the 300 series in use
at the APS (XOR 8-ID). They are using the PS350. Let me
know if you want to try it.
The support is asyn/streams based.
I have found the GPIB interface to these devices a bit flacky and
required that the GPIB controller be in 'timeout mode' for it to be
reliable. The result was a very slow (2 times sec) update rate.
SRS insisted that there is not a know problem with the unit (shrug).
Joe
RE: Update rate...2 Hz was a typo...each message takes 300ms, so a full update (3
messages)  takes a little short of a second.
Stanford Research PS310 Power Supply James Stevens
Re: Stanford Research PS310 Power Supply Joe Sullivan
Prev: Re: Stanford Research PS310 Power Supply Joe Sullivan
Next: RE: EDM Properties Windows Kevin Anderson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: misleading error message from dbLoadRecords in Epics 3.14.8.2 Goetz Pfeiffer
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
