1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: ADEL field in motor record
To: <[email protected]>
Date: Wed, 10 Jun 2009 12:26:05 +0100
At DLS we are currently attempting to reduce our PV archiving load. Some of the data that we archive is effectively noise, so we are setting up the use of ADEL wherever possible.
The current version of the motor record doesn't have an ADEL field, which means that if we set an archive monitor on RBV (the motor controller readback value) then we archive every change of RBV, including encoder noise or insignificant servo motor changes.
Would anyone have a problem with me adding ADEL to the motor record? The default value for ADEL would be zero, so that no change in default behaviour is seen. But it can then be set to a sensible value for archiving.
I would implement it in the same way as it's done for the analogue input record. So this means an additional ALST field for use in the monitor() function.
While I'm at it I could also add an MDEL field to enable a value monitor deadband.
Cheers,
Matthew
DLS controls
Re: ADEL field in motor record Ron Sluiter
ASYN Connection feedback Mathew Hicks
Prev: ASYN Connection feedback Mathew Hicks
Next: Re: ADEL field in motor record Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
