1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: problem about environment variables under vxWorks-6.6
To: [email protected]
Date: Fri, 12 Jun 2009 13:22:20 +0200
Hi, all,
It's OK after I add 5 seconds delay at the beginning of rsrv_online_notify_task(), but I can't explain it.
@Andrew and Jeff, thank you.
Gongfa
Andrew Johnson wrote:
This message is from Gongfa Liu, I'm forwarding it while the APS sysadmins figure out why all email from DESY is being caught as spam... - Andrew
Hi, all,
I created an ioc application with makeBaseApp.pl for test under the
following environment:
   epics base:          3.14.10
   vxWorks:             6.6
   target architecture: vxWorks-pentium
I got a waring message after iocInit:
   "The CA server's beacon address list was empty after initialization?"
This waring message is from ~base/src/rsrc/online_notify.c, I use
epicsEnvShow(NULL) and epicsPrtEnvParams() to print the environment
variables at the position where the warning message is created, but
nothing is printed. It seems that the environment variables set is not
inherited. What is missing in the vxWorks image? Any suggestions are
appreciated.
Thank you.
Gongfa Liu
Gongfa Liu                         MKS-2, DESY
phone:  +49-40-8998-1642           Notkestr. 85
fax:    +49-40-8998-4388           22607 Hamburg
e-mail: [email protected]         Germany
problem about environment variables under vxWorks-6.6 Andrew Johnson
Prev: RE: problem about environment variables under vxWorks-6.6 Jeff Hill
Next: help for developing a simple application on EPICS D.Chinnadurai
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: FW: problem about environment variables under vxWorks-6.6 Jeff Hill
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
