1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Pfeiffer Turbo Pump /controller
To: "Vesna Samardzic-Boban" <[email protected]>, <[email protected]>
Date: Wed, 17 Jun 2009 09:05:12 +0100
Vesna,
I have a stream device application for the Pfeiffer TPG 256 A MaxiGauge controller
if that is of any help.
Pete
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]]On Behalf Of Vesna
> Samardzic-Boban
> Sent: 17 June 2009 07:12
> To: [email protected]
> Subject: Pfeiffer Turbo Pump /controller
> Hi All,
> Has anyone interfaced to EPICS via serial interface Pfeiffer
> Turbo-Molecular Pump station?
> Our set is comprised of:
> Turbomolecular pump TMH 071 P integrated with TC 100 electronic drive,
> Display Control Unit DCU 100 and
> Connection box TC 010.
> Or any other controller from Pfeiffer  to EPICS.
> Thanks and regards
> Vesna
> Vesna Samardzic-Boban | Controls Engineer | Australian Synchrotron
> [email protected] | www.synchrotron.org.au
> 800 Blackburn Road, Clayton, Victoria 3168
> <br>This message and any attachments may contain proprietary
> or confidential information. If you are not the intended
> recipient or you received the message in error, you must not
> use, copy or distribute the message. Please notify the sender
> immediately and destroy the original message. Thank you.
Scanned by iCritical.
Re: Pfeiffer Turbo Pump /controller J. Lewis Muir
Pfeiffer Turbo Pump /controller Vesna Samardzic-Boban
Prev: Pfeiffer Turbo Pump /controller Vesna Samardzic-Boban
Next: Re: Pfeiffer Turbo Pump /controller J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
