1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MVME 5500
To: "Andrew Johnson" <[email protected]>, <[email protected]>
Cc: GOURNAY Jean-Francois <[email protected]>
Date: Fri, 19 Jun 2009 16:32:50 +0100
Hi Jean-Francois,
We have 5500's running VxWorks and don't suffer from this problem.
VxWorks should be in Flash 0, and MOTLoad in Flash 1. Use J8 to select
which bank of flash to boot from. Jumper pin 1-2 for VxWorks and 2-3 for
MOTLoad.
Removing jumper J9 should disable writing to Flash 0, which is what
Andrew wanted to find out. However, I think we have J9 installed, so I
am a bit surprised at your problem. You may, however, a very specific
loose pointer.
Cheers,
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Andrew Johnson
> Sent: 19 June 2009 15:21
> To: [email protected]
> Subject: Re: MVME 5500
> Hi Jean-Francois,
> On Friday 19 June 2009 06:25:29 GOURNAY Jean-Francois wrote:
> > Whenever a C program has a misbehaved pointer, which causes a
> > memory-write outside the allocated data memory, we have a
> crash of the
> > CPU which is absolutely understandable, but then, it is
> impossible to
> > reboot the CPU. Both flash banks containing the initial
> bootload and the
> > VxWorks boot are corrupted and the only solution is to send
> back the CPU
> > to the retailer !!! We had experienced this with several
> CPUs (we are
> > probably bad C programmers) and didn't get so far any
> explanation from
> > our retailers or after sales services. We have VxWorks 6.5.
> Does this board have write-protect jumpers for the Flash?
> Most of the other
> MVME boards do, but I can't get to the hardware documentation for the
> MVME5500 right now on the Emerson website so I can't check
> that for myself.
> If it does they should at least be able to prevent the flash
> from getting
> corrupted when things go wrong.
> HTH,
> - Andrew
> The best FOSS code is written to be read by other humans --
> Harold Welte
Scanned by iCritical.
RE: MVME 5500 GOURNAY Jean-Francois
Re: MVME 5500 Andrew Johnson
Prev: RE: Epics extension problems Dudley, David
Next: Re: A problem about edm Dayle Kotturi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: MVME 5500 Andrew Johnson
Next: RE: MVME 5500 GOURNAY Jean-Francois
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
