1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: A problem about edm
To: "Kasemir, Kay" <[email protected]>
Cc: Tech-talk <[email protected]>
Date: Fri, 19 Jun 2009 12:26:21 -0500
The "multiple servers" response also happens when using VirtualBox to run virtual guest operating systems (such as Linux within a WindowsXP host like my laptop). The guest host is on the 10.0.x.x subnet. VirtualBox sets up a "VirtualBox Host-Only Network" network connection. Disable that connection and close VirtualBox to remove that problem, if it presents itself.
Kay's solution might be an alternative resolution and I'll try it soon.
-- Pete
Kasemir, Kay wrote:
Hi:
Could it be that 10.30.53.51 localhost.localdomain is the
same computer?
I've seen cases on laptops, trying to access a soft IOC on the
same laptop, where I got multiple responses for the "real" IP
as well as 127.0.0.1.
The workaround was to set EPICS_CA_ADDR_LIST=127.0.0.1,
EPICS_CA_AUTO_ADDR_LIST=NO.
Kay
On 6/19/09 12:44 , "Dayle Kotturi" <[email protected]> wrote:
You have the PV loaded onto (at least) two nodes on the subnet
(or list of IP addresses in your EPICS_CA_ADDR_LIST) that edm is using.
Edm is behaving as it should, it's just getting two replies fo the
PV "X15U1:EH:DXP:Z".
This can also happen if you have a gateway and edm can "see" both the
source IOC's PV and the gateway's copy.
    Warning: "Identical process variable names on multiple servers"
    Context: "Channel: "X15U1:EH:DXP:Z.BUSY", Connecting to:
10.30.53.51:5064, Ignored: localhost.localdomain:5064"
 Pete R. Jemian, Ph.D.                <[email protected]>
 Beam line Controls and Data Acquisition, Group Leader
 Advanced Photon Source,   Argonne National Laboratory
 Argonne, IL  60439                   630 - 252 - 3189
    Education is the one thing for which people
       are willing to pay yet not receive.
Re: A problem about edm Kasemir, Kay
Prev: Re: A problem about edm Kasemir, Kay
Next: 答复: A problem about edm 汪启胜
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: A problem about edm ??
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
