1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: re: "A32 RegisterAddress error" about Hytec8401
To: <[email protected]>
Date: Thu, 25 Jun 2009 16:19:17 +0800
Hi all,
Thank you for your reply! The problem was done.
One guy gave me a  bootrom.bin  file, and I flash it into mvme5500 Boot Rom. Finally the hytec8401 works well. But really I don’t know the secret of bootrom.bin file.
Best regards,
LIU Ping
Send: 2009.6.16
11:40
to: [email protected]
subject: "A32 RegisterAddress error" about Hytec8401
As a fresh man, I need your help. The hardware is Hytec8002 and hytec8401. Hytec8401ip driver came from Diamond website. I made my own application project with EPICS V3.14.8.2 and VxWorks V5.5.1. The codes compiling is no error but some warnings. When downloaded to VME(mvme5500), there are some error message as below:
## Load record instances
dbLoadRecords("db/8401.db")
value = 0 = 0x0
#                                      slot int options
IPCAC6 = ipacEXTAddCarrier(&EXTHy8002, "6 2 10")
Id: drvHy8002.c,v 1.10 2001/11/20 12:21:42 wscott Exp
8002 initialise 6 2 10
PROM manufacturer ID: 0x8003 (HyTec Electronics Ltd., Reading, UK)
PROM model #: 0x8002, board rev. 0x03
PROM Xilinx rev.: 0x03, 0x00, 0x07
PROM Serial #: 0x00 0x00 0x00 0x00 0x05 0xce
drvHy8002filename="../.: A32 RegisterAddress error (status=./..34144267/src/libCom/)osi/devLib.c" line vmeslot number=282
6, ipslot unable to m0ap address VME A32  at address base=0X11800000800000 size =
 0X100000
0xIP memo1ef31290ry register  (error!
tShell): drvHy8002ipacAddCarrie: Cannot register A32 device at r: 1800000Hytec VICB8002. Error is  driver retur209000bned an error.
new symbol "IPCAC6" added to symbol table.
IPCAC6 = 0x1ee87ff0: value = -1 = 0xffffffff
#-------- 8401 (Analogue Input)------------------------------------------------
#                    card,  slot, ipsl, intl, inte, aity, clks,  clkr, inhi, samp, spac, trig
Hy8401ipConfigure ( 60, IPCAC6,    A,  0,    0,    0,    0,    15,    0,  1,    1,    0)
$Id: drvHy8401ip.c,v 1.8 2005/10/27 09:07:01 mga83 Exp $
Hy8401ipConfigure: card 60, VME slot -1, IP slot 0,
           vector 0, itr state 0, ai type 0,
           clock src 0, clock rate 15, inhibit 0,
           samples 1, spacing 1, trigger 0
value = 0 = 0x0
shellPromptSet "1054-Test> "
value = 2178076 = 0x213c1c = shellHistSize + 0x4
iocInit()
Starting iocInit
###  EPICS IOC CORE built on Jul 16 2008
###  EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
***drvIpac version extended for Hot Swap
***$Id: drvIpac.c,v 1.3 2004/05/17 10:57:14 pho Exp $
SPAWNING HOTSWAP SCAN TASK
0x1ef31290 (tShell): drvHy8401ip: Cannot register Hy8401ip A16 device.iocInit: All initialization complete
value = 0 = 0x0
Done executing startup script /home/blctrl/hytec_ADC/iocBoot/iocHy8401ADC/st.cmd
1054-Test>
I check out the error “A32 RegisterAddress error” come from the line 667 of drvHy8002.c file
How to correct? Thanks a lot!
LIU Ping
Beamline Control Group
Shanghai Synchrotron Radiation Facility
Shanghai Institute of Applied Physics
Chinese Academy of Sciences
Zhangheng Rd 239,Pudong Dist.,
Shanghai 201204
China
Tel:+86-21-33933237
Re: "A32 RegisterAddress error" about Hytec8401 Matthieu Bec
"A32 RegisterAddress error" about Hytec8401 liuping
Prev: Troubles building jca.jar Pacios Rodriguez Luis Orlando
Next: Re: "A32 RegisterAddress error" about Hytec8401 Matthieu Bec
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: "A32 RegisterAddress error" about Hytec8401 Rees, NP (Nick)
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
