1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: medmCAExceptionHandlerCb: Channel Access Exception message
Cc: Tech-talk <[email protected]>
Date: Wed, 1 Jul 2009 08:10:28 -0500
On Jul 1, 2009, at 8:04 AM, Mark Rivers wrote:
David,
The medm message is "normal" because your IOC is exiting for some reason. You need to find the reason for that. It's strange that the IOC exits with no message, so it may be a bit difficult to track down. It have not seen that. Some systems are set up with an inactivity timer that will log you out after some period of inactivity, but that should kill your ssh session, not just the IOC application.
If the IOC is terminating unexpectedly you should try running it under GDB and capture what's going on.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
medmCAExceptionHandlerCb: Channel Access Exception message David Kline
RE: medmCAExceptionHandlerCb: Channel Access Exception message Mark Rivers
Prev: RE: medmCAExceptionHandlerCb: Channel Access Exception message Mark Rivers
Next: Re: Prodex MAXv command responses (RA, QA, EA, RL) for different versions of firmware Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: CA environment variables not being set? Shawn Smith
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
