Zen,
You can get a file chooser with the text control widget. The incantation
is in the online doc as
Editable + keypad + file + pv type = string: edit with file select box
With these options you also set "default dir" and "pattern" to something
like "./" and "*.txt" respectively.
You also choose the form of the returned string which may be "full
path", "name & ext", or "name only".
Szalata, Zenon M. wrote:
I have written a soft IOC which reads data from a disk file and places values read into EPICS records. A few EDM screens are used to display the data...
All of this works fine.
There a number of disk files to choose from.
I have implemented a simple way to specify the file name using a waveform record and a text control. This scheme is very difficult to use.
I think that EDM does not provide a file name chooser dialog. Is that true?
If so, has anyone implemented some EDM widget which could be used to choose a file name from existing files on a disk drive?
Thanks in advance,
Zen
- choosing snmp version Pierrick Hanlet
- File Chooser Szalata, Zenon M.
Re: EDM X-Y Graph zoom shrinks with its zoom? John Sinclair
Re: Detecting data lost from a subscriber Ralph Lange
<2009>
2025
RE: File Chooser Munro Jr, John K.
Re: choosing snmp version Euan Troup
<2009>
2025
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
