1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: sub routine record doesn't get value via INPD
To: EPICS tech-talk <[email protected]>
Date: Mon, 13 Jul 2009 20:24:27 +0200
Hi all,
I have the following problem (EPICS 3.14.10 / Debian 4.0)
with this tiny database (minimized to my problem) .
Why don't I see the Value/Raw Value of "HAD:RPC:S1:M0:C9:ToTL" at the
input D of the sub record "HAD:RPC:S1:M0:C9:stToTL", which I try to
access at c-code.
1) The ingredients:
> record(ao, HAD:RPC:S1:M0:C9:ToTL) {
>   field(DESC, "0 0 0 2")
>   field(DTYP, "Raw Soft Channel")
>   field(FLNK, "HAD:RPC:S1:M0:C9:stToTL")
>   field(OUT, "HAD:RPC:S1:M0:C9:stToTL")
>   field(EOFF, "0")
>   field(LOPR, "0")
>   field(HOPR, "199")
>   field(DRVH, "250")
>   field(DRVL, "0")
>   field(LINR, "LINEAR")
>   field(OMSL, "supervisory")
> record(sub, HAD:RPC:S1:M0:C9:stToTL) {
>   field(DESC, "store 0 0 0 2")
>   field(INAM, "mySubInit")
>   field(SNAM, "myStoreFcn")
>   field(INPA, "0")
>   field(INPB, "0")
>   field(INPC, "2")
>   field(INPD, "HAD:RPC:S1:M0:C9:ToTL.RVAL")
>   field(INPE, "0")
The referenced C-Code:
> static long myStoreFcn(subRecord *precord)
>   short thr;
>   thr = precord->d;
>   printf( "Record %s called myStoreFcn(%p), thr %d, precord->d %f\n",
>            precord->name, (void*) precord, thr, precord->d);
>   return(0);
> epicsRegisterFunction(myStoreFcn);
2.) The test: (caput / dbpf)
> epics> dbgf HAD:RPC:S1:M0:C9:ToTL
> DBR_DOUBLE:         0
> epics> dbpf HAD:RPC:S1:M0:C9:ToTL 200
> Record HAD:RPC:S1:M0:C9:stToTL called myStoreFcn(0x80577b0), thr 0,
> precord->d 0.000000
> DBR_DOUBLE:         200
> epics>dbpr HAD:RPC:S1:M0:C9:stToTL
> A: 0                ASG:                B: 0                C: 2
> D: 0                DESC: store 0 0 0 2 DISA: 0             DISP: 0
> DISV: 1             E: 0                F: 0                G: 0
> H: 0                I: 0                J: 0                K: 0
> L: 0                NAME: HAD:RPC:S1:M0:C9:stToTL           SEVR: NO_ALARM
> STAT: NO_ALARM      TPRO: 0             VAL: 200
3. ) The (stupid) question: Why don't I get the value of
HAD:RPC:S1:M0:C9:ToTL at D? At VAL I see it.
Thanks  for any explanation.
Peter
 Dr. rer. nat. Peter W. Zumbruch
 EE - department / Controls group / GSI
 E-Mail: P.Zumbruch_at_gsi.de
 Tel: +49-(6159)-71-1435 / Fax: +49-(6159)-71-2986
 GSI Helmholtzzentrum für Schwerionenforschung GmbH
 Planckstraße 1 / D-64291 Darmstadt / www.gsi.de
 Gesellschaft mit beschränkter Haftung
 Sitz der Gesellschaft: Darmstadt
 Handelsregister: Amtsgericht Darmstadt, HRB 1528
 Geschäftsführung: Professor Dr. Horst Stöcker, Christiane Neumann
 Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph,
 Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
Re: sub routine record doesn't get value via INPD Maren Purves
Re: sub routine record doesn't get value via INPD Andy Foster
Re: sub routine record doesn't get value via INPD Andrew Johnson
Prev: DB CA link to PROC field Benjamin Franksen
Next: Re: sub routine record doesn't get value via INPD Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: DB CA link to PROC field Tim Mooney
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
