1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: GE Fanuc
Date: Sun, 19 Jul 2009 20:28:36 -0400
Plan right now is to use Irmis as our hardware and configuration management
system.  We're expanding and re-targeting it to be able to track everything
from the field equipment on one end all the way through the wiring system,
physical PLC wiring configuration, up to hopefully a fair amount of the PLC
logic.
Currently, the only PLC we've looked at the has the capability of accepting
a complete definition from the IRMIS system looks like probably the AB.  It
can load and store XML files that can describe the complete PLC program and
I/O configuration.
GE appears to have the capability of doing the same thing, to some degree,
but so far I have been unable to get concrete information on it.
I'm looking at the PACSystem RS7i system because it's VME64 based, has high
I/O count modules, and fits in a 19" rack.
Hope to get more information this week.
David
On 7/19/09 6:43 PM, "Bryce Karnaghan" <[email protected]>
wrote:
> David
> Also look at the programming tools, we use mostly Schneider PLCs (although we
> do have most other flavours on site) and UnityPro to program them. The backend
> of UnityPro is XML driven and so you can use Unix "Make" and your favourite
> regular expression/string handling tools to build the whole PLC from a script.
> Very handy  for large I/O counts where you have a lot of similar code that
> becomes tedious to manage in the native click and point environment.
> If you mange these scripts in CVS or similar it also becomes very easy to diff
> the scripts to see what might have changed between versions.
> regards
> Bryce Karnaghan | Controls Specialist | Australian Synchrotron
> p: (03) 8540 4135 | f: (03) 8540 4200 | m: 0423 844 592
> [email protected] | www.synchrotron.org.au
> 800 Blackburn Road, Clayton, Victoria 3168
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On
> Behalf Of David Dudley
> Sent: Saturday, 18 July 2009 5:50 AM
> To: [email protected]
> Yes, I'd very much like to get in contact with your local expert.
> We're looking at the AB ControlLogix and CompactLogix (particularly the
> Compact) as well.  Also looking at the Siemens S7-300 and Yokogawa FA-M3
> product lines.
> They all definitely have advantages and disadvantages.
> The real plus for the AB is it's support of CIP, which puts interfacing with
> EPICS fairly easy.
> The Siemens - well - it's Siemens - you either love them, or you don't.
> Yokogawa certainly has an interesting product with the FA, for which there
> is an actual EPICS IOC that directly executes on the thing (although I'm
> told it's kind of expensive - I haven't seen any pricing on it).
> The GE however, seems to have the kind of power and high point count
> integration we're needing.  None of the other PLCs have high channel count
> analogs (GE has 64 channel 16 bit), or high count Digitals (GE and Yokogawa
> both have 64 bit DI's and DO's).
> Other problem is space.  Only the GE is going to easily fit 19" rack spaces
> efficiently.
> Gotta expand my spreadsheet for comparison quite a bit.
> David
> On 7/17/09 3:22 PM, "Elliott Wolin" <[email protected]> wrote:
>> Hi,
>> We plan to use Allen-Bradley ControlLogix PLC's for our control system,
>> but are using GE Fanuc core-duo cpu's for data acquisition. If you have
>> any interest in the latter I can put you in contact with our local expert.
>> Sincerely,
>> Elliott
>>  Those raised in a morally relative or neutral environment will hold
>>    no truths to be self-evident.
>> Elliott Wolin
>> Staff Physicist, Jefferson Lab
>> 12000 Jefferson Ave
>> Suite 8 MS 12A1
>> Newport News, VA 23606
>> 757-269-7365
>> David Dudley wrote:
>>> I¹m over at BNL NSLS2 now, and have been given the task of providing
>>> recommendations as to the types of PLCs to support.
>>> I¹ve been looking at the GE PACSystems among others, and Bob has
>>> suggested I should ask on the mailing list as to whether anyone has
>>> experience in using the GE Fanuc family in accelerator controls.
>>> David Dudley
> <br>This message and any attachments may contain proprietary or confidential
> information. If you are not the intended recipient or you received the message
> in error, you must not use, copy or distribute the message. Please notify the
> sender immediately and destroy the original message. Thank you.
RE: GE Fanuc Bryce Karnaghan
Prev: RE: GE Fanuc Bryce Karnaghan
Next: RE: pseudo coloring of video stream Cobb, TM (Tom)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Job Posting Eric Berryman
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
