1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: labview w/ CA
To: Jeffrey Holt <[email protected]>, [email protected]
Date: Sat, 25 Jul 2009 11:33:50 +0200
Jeff,
Do you know if LabView 2009 with CA support will work on Linux as well
as Windows?  I would be vert interested in if it works with Linux (OK,
I am interested in how well it works with Windows).
On Wed, Jul 22, 2009 at 12:16 AM, Jeffrey Holt<[email protected]> wrote:
> The newest version of LabVIEW (2009, due out next month) supposedly has full
> support for CA through the use of their "EPICS I/O Server" which will load
> an EPIC .db file and create a new set variables. These can then be tied
> directly into LabVIEW shared variables which are extremely easy to use.
> This architecture has actually been available in LV applications running on
> a PC for a couple of versions (I think). I'm pretty good at LV (but really
> bad in EPICS) and have successfully created this reasonably direct
> connection with LV version 8.6 and EPICS 3.14.
> LabVIEW 2009 supposedly now supports the same thing on Real-Time
> controllers. I am (this week) attempting to run an advance LV 2009 copy in
> the manner described. I will be very happy if this works...
> Cheers,
> -Jeff
> On 7/20/09, Wesley Moore <[email protected]> wrote:
>> tech-talkers,
>>   Yes I know this has been done, but what's the difficulty in setting this
>> up?  What is the preferred method and has the experience been good or bad?
>>  It seems like the decision to support this is based on extent of it's
>> usage.
>> Thanks for any comments,
>> Wesley
Re: labview w/ CA Andy Foster
labview w/ CA Wesley Moore
Re: labview w/ CA Jeffrey Holt
Prev: RE: checking for change in value in device support function Mark Rivers
Next: Re: labview w/ CA Andy Foster
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: labview w/ CA Wesley Moore
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
