At Diamond we have a requirement for a text monitor/update widget that
handles strings of more than 40 characters, spread over several lines.
To provide this I implemented a multi-line text update widget that takes
its input from a text string in a waveform record instead of a stringin
or stringout. Long lines are split at spaces, and "\n" characters are
handled correctly. This widget can be found in the standard EDM
distribution, in the diamondlib directory. I hope it is of use to you.
Regards
Steve Singleton
-----Original Message-----
[mailto:[email protected]] On Behalf Of Szalata, Zenon M.
Sent: 02 August 2009 06:05
To: [email protected]
Subject: EDM: Text Monitor Widget
I have an ASCII coded string which contains new line characters.
Effectively, the null terminated string contains a small number of
"lines". This string is formatted in genSub record and the output field
in which the string is held is of type "CHAR" and of length n
characters, long enough to hold the string.
When I display this string in an EDM Text Monitor widget, the new line
characters are displayed as (0A) and the text that follows is not
displayed on next line. I was hoping that the new line character
imbedded in a string would have the expected behavior. In fact, Text
Monitor, Text Update, and Text Control, all do the same thing with the
new line character.
Is there a way in EDM to display such a string effectively as printf
would?
I know that I could break up the string into separate lines of text, one
per EPICS record, but that would end up with a lot of extra record and
much extra work. Besides, it would be difficult to handle a variable
number of lines of text...
Thanks in advance,
Zen
Scanned by iCritical.
- EDM: Text Monitor Widget Szalata, Zenon M.
RE: Roper Quad-RO locks up with areaDetector/ccd apps Mark Rivers
Re: Roper Quad-RO locks up with areaDetector/ccd apps tieman
<2009>
2025
FW: EDM: Text Monitor Widget Szalata, Zenon M.
<2009>
2025
