1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to let Hytec8401ADC works on interrupt way ?
To: [email protected], [email protected]
Cc: [email protected], [email protected]
Date: Wed, 26 Aug 2009 10:26:35 +0100
Hi Liu,
You do not need to change / set any switches on the hardware, the setup is software contolled (assuming you are using our 8002 carrier).Your VME64x crate should not need any configuing for interrupt operation from your carrier. I'm on an exhibition stand at FEL09 and several staff are on holiday at the moment. We will send you a direct email reponse shortly.
We now have a tested Asyn driver for the 8401 available that uses "I/O Intr" mode tested up to 20Khz.
Graham Cross
Hytec Electronics Ltd.
This message was sent using IMP, the Internet Messaging Program.
How to let Hytec8401ADC works on interrupt way ? liuping
Prev: problem using epid record Maurizio Montis
Next: RE: problem using epid record Pal Trivan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: How to let Hytec8401ADC works on interrupt way ? liuping
Next: re: How to let Hytec8401ADC works on interrupt way ? liuping
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
