1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: casr bug
To: tech-talk <[email protected]>
Date: Thu, 03 Sep 2009 11:43:13 +0200
To whomever feels responsible for casr
I found a bug in casr. Empty strings were saved as data{} (in ascii format) but
cannot be restored. The fix below stores empty strings as data{""}.
There are still other issues: It is not possible to restore a string that
contains a quote (") or that ends with a backslash (\). Both result in syntax
errors. Restoring a string that contains special characters like äöü sometimes
hangs up carestore.
Best regards,
Dirk
*** common.c.orig       2009-09-03 11:33:15.000000000 +0200
--- common.c    2009-09-03 11:33:21.000000000 +0200
*** 502,507 ****
--- 502,512 ----
      char    *p = Value;
+     if (!*p)
+         fputs("\"\"", file);
+         return;
      while(*p)
if (!isalnum(*p) && (*p != '.') && (*p != ':') && (*p != '+') && (*p != '-') && (*p != '_'))
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
Re: casr bug Andrew Johnson
Prev: Re: Problem building EPICS base 3.14.11 Andrew Johnson
Next: Re: casr bug Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
