Hello,
I'm having problems with inistalling EPICS on Ubuntu Linux. I've
downloaded EPICS Base R3.14.10 and the following modules: Asyn,
drvIpac and Sequencer compiler 2.0.11. These were all compiled ok.
I've also installed the GNU readLine library, so I didn't have to
comment out the line in the config file.
So it all compiled fine, I've set the environment variables in .bashrc:
export EPICS_CA_ADD_LIST=127.0.0.1
export EPICS_ROOT=/opt/epics
export EPICS_HOST_ARCH=linux-x86
export EPICS_BASE=$EPICS_ROOT/base
export EPICS_EXTENSIONS=$EPICS_ROOT/extensions
export PATH=$PATH:$EPICS_BASE/bin/$EPICS_HOST_ARCH
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$EPICS_BASE/lib/$EPICS_HOST_ARCH:$EPICS_EXTENSIONS/lib/$EPICS_HOST_ARCH:$EPICS_APPS/lib/$EPICS_HOST_ARCH
Then I've created an example application in the "work3" directory:
makeBaseApp.pl -t example myexample3
makeBaseApp.pl -i -t example myexample3
It all worked fine, I wrote "make" and the application was built.
However, when I started the application, it didn't work fine. It says
for example "unknown type ai" and "unknown type calc". I'm guessing it
cannot find the database. This is the complete output:
user@ubuntu-vmware:~/work3/iocBoot/iocmyexample2$
../../bin/linux-x86/myexample2 st.cmd
#!../../bin/linux-x86/xxx
## You may have to change xxx to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("IOC","iocmyexample2")
epicsEnvSet("TOP","/home/user/work3")
epicsEnvSet("EPICS_BASE","/opt/epics/base")
cd /home/user/work3
dbLoadDatabase "dbd/xxx.dbd"
filename="../dbLexRoutines.c" line number=243
No such file or directory dbRead opening file
dbd/xxx.dbdxxx_registerRecordDeviceDriver pdbbase
st.cmd -- Line 12 -- Command xxx_registerRecordDeviceDriver not found.
## Load record instances
dbLoadTemplate "db/userHost.substitutions"
Record "userHost:aiExample" is of unknown type "ai" - Error at or
before ")" in file "db/dbExample1.db" line 1
Record "userHost:calcExample1" is of unknown type "calc" - Error at or
before ")" in file "db/dbExample2.db" line 1
Record "userHost:calcExample2" is of unknown type "calc" - Error at or
Record "userHost:calcExample3" is of unknown type "calc" - Error at or
dbLoadRecords "db/dbSubExample.db", "user=userHost"
Record "userHost:subExample" is of unknown type "sub" - Error at or
before ")" in file "db/dbSubExample.db" line 1
## Set this to see messages from mySub
#var mySubDebug 1
## Run this to trace the stages of iocInit
#traceIocInit
cd /home/user/work3/iocBoot/iocmyexample2
iocInit
Starting iocInit
## EPICS R3.14.10 $R3-14-10$ $2008/10/27 19:39:04$
## EPICS Base built Sep 3 2009
initPeriodic: menuScan not present
## Start any sequence programs
#seq sncExample, "user=userHost"
epics> exit
Any idea what could be wrong, and how to fix it?
Thanks, Csaba
- RE: Problems with installing EPICS Rees, Nick (DLSLtd,RAL,DIA)
- Re: Problems with installing EPICS Andrew Johnson
sequencer feature request Patrick Thomas
<2009>
2025
RE: sequencer feature request Mark Rivers
<2009>
2025
