Hi Patrick,
Someone might correct me, but I don't believe that there is a way
to get a list of the PVs/IOC. In linux, you can always take the database
ascii file and do a grep on "record". That will give you a list of all
PVs for that IOC.
As for your second problem, one of my colleagues found this.
You need to add the following lines to add a hack to the alBeep()
function which uses a system command to play a sound file, e.g.:
/* Additional include */
#include <stdlib.h>
int alBeep(Display *displayBB)
/* Additional 'beep' command */
/* (needs error checking...) */
system("play /path/to/beep.wav");
XBell(displayBB, 0);
return 0;
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039 office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
----- Original Message -----
Date: Saturday, September 12, 2009 3:19 am
Subject: list all process variables, linux alarm handler
To: [email protected]
> Hi,
> I was wondering if there was anyway to get a list of all the process
> variables currently loaded in all the IOCs. I read that when a request
> for a particular process variable is made, each IOC gets the request
> and
> has to look in its databases to see if it contains it. Is it possible
> to
> instead have it return all the process variables it does have?
> I was also wondering if anyone has had trouble getting the sound to
> work
> when compiling the alarm handler on Linux?
> Thank you,
> Patrick
- list all process variables, linux alarm handler Patrick Thomas
Re: list all process variables Ralph Lange
Re: list all process variables Noboru Yamamoto
<2009>
2025
<2009>
2025
