1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Getting String Form of Enums
To: David Brodrick <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 18 Sep 2009 08:54:11 -0400
Hi:
JCA/CAJ is very close to the original Channel Access
client library, so just as with it you have the choice between
a) Always get the enum as a DBR_STRING.
   "Works", gives you the string, but asks the IOC to
   produce the string when fetching the number would be a tiny bit
   more efficient. Besides, you might really want both the number
   and the state string.
b) Get the DBR_CTRL_ENUM once(!), which gives you the enum strings,
   then continue to just read the number.
   Seems perfect, because more efficient and now you have both
   number and string.
   But DBR_CTRL_ENUM  only gives you a maximum of 16 enums,
   while in fact there might be more options for certain enumerated values.
Your pick.
-Kay
On 9/18/09 01:16 , "David Brodrick" <[email protected]> wrote:
> Tech-talkers,
> I am using JCA/CAJ and I am wondering about the best way to determine
> the string representation of the current value for enumerated records
> such as bi, mbbi, etc.
> Given the current numeric VAL, do I need to explicitly do an additional
> CA call to find out the appropriate string mapping (eg to find out the
> string for ONAM), or is there an easier way?
> Many thanks,
>   David
>  David Brodrick, Software Engineer
>  CSIRO Australia Telescope National Facility
>  Locked Bag 194, Narrabri, NSW 2390, Australia
>  Work: 02 6790 4038  Fax: 02 6790 4090
>  mailto:[email protected]
Getting String Form of Enums David Brodrick
Prev: Re: About Bruker AXS Jens Eden
Next: more list all process variables... Sue Witherspoon
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Getting String Form of Enums David Brodrick
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
