1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: alarm handler on base 3-14-11
To: Patrick Thomas <[email protected]>
Cc: [email protected]
Date: Thu, 24 Sep 2009 09:57:33 +0800
Install ncurses library by yourself.
On Thu, Sep 24, 2009 at 9:47 AM, Patrick Thomas
<[email protected]> wrote:
> Thank you, that seems to have worked. However, now it errors on 'cannot find
> -lncurses' for g++ -o alh.
> Mark Rivers wrote:
>> This is a common change required in 3.14.11.
>>  You need to "#include menuYesNo.h" and YES needs to be changed to
>> menuYesNoYES.
>>  Mark
>> ________________________________
>> From: [email protected] on behalf of Patrick Thomas
>> Sent: Wed 9/23/2009 8:00 PM
>> To: [email protected]
>> Subject: alarm handler on base 3-14-11
>> Hi,
>> I was wondering, I get a compile error on force.c when running make on
>> the alarm handler with epics-3-14-11, on 64 bit linux:
>> /usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
>> -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux
>>  -D_REENTRANT   -O3   -Wall      -m64     -g  -I. -I../O.Common -I.
>> -I../os/default -I.. -I../../../include/os/Linux -I../../../include
>> -I/users/thomas/epics/base/base-3-14-11/include/os/Linux
>> -I/users/thomas/epics/base/base-3-14-11/include         -I../os/Linux
>> -I../os/default -I/usr/include -I/usr/include/X11    ../force.c
>> ../force.c: In function 'forcePVUpdateFields':
>> ../force.c:1028: error: 'YES' undeclared (first use in this function)
>> ../force.c:1028: error: (Each undeclared identifier is reported only once
>> ../force.c:1028: error: for each function it appears in.)
>> make[2]: *** [force.o] Error 1
>> make[2]: Leaving directory
>> `/users/thomas/epics/extensions/src/alh1_2_24/O.linux-x86_64'
>> make[1]: *** [install.linux-x86_64] Error 2
>> make[1]: Leaving directory `/users/thomas/epics/extensions/src/alh1_2_24'
>> make: *** [alh1_2_24.install] Error 2
>> Thank you,
>> Patrick
Best Regards
Chen
          Zhi-chu Chen | Shanghai Synchrotron Radiation Facility
         No. 2019 | Jialuo Rd. | Jiading | Shanghai | P.R. China
             tel: 086 21 5955 3405 | zhichu.chen.googlepages.com
                                               | www.sinap.ac.cn
Re: alarm handler on base 3-14-11 Patrick Thomas
RE: alarm handler on base 3-14-11 Mark Rivers
Prev: Re: alarm handler on base 3-14-11 Patrick Thomas
Next: Re: alarm handler on base 3-14-11 Patrick Thomas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
