1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Python client application survey
To: [email protected]
Date: Wed, 30 Sep 2009 18:30:26 +0200
On Wednesday 30 September 2009, Matt Newville wrote:
> For example, I don't see significant advantages to having all the C CA
> types (DBR_SHORT, DBR_INT, DBR_LONG, etc) exposed to Python at all, as
> Python does not distinguish these types, and the difference never
> needs to be exposed to the Python programmer.
It /is/ a difference to the server whether you request DBR_SHORT, DBR_INT,
or DBR_LONG. These will trigger different conversion routines, and thus
might give different results.
> The DBR_ type for a
> channel is an implementation detail that is important in C, but not in
> Python.
If it is not important in Python, then why should it be important in C?
> One should be able to create a channel/PV in Python without
> knowing its underlying type.
Yes, but field type is different from request type!
You /don't/ want to use the native (field) type for all queries, for
instance overlong string fields might actually be implemented in the
database as a DBF_CHAR array. Requesting the native type will be wrong, in
this case. OTOH, a DBF_CHAR array might also be meant as a vector of 8-bit
numbers. The client program must know and choose the correct interpretation
by chosing the correct request type.
I think it is a very good idea to map the /complete/ C API to a low-level
python CA lib.
> I also think there is no point in ever seeing the Channel ID in Python,
> as this should always be inside a Channel or PV object.
Of course, but is a totally different matter as we can easily arrange that
there is an exact one-to-one mapping between objects and IDs. With request
types this is not the case as demonstrated above.
Cheers
Ben
Re: EPICS Python client application survey Andrew Johnson
Re: EPICS Python client application survey Matt Newville
Prev: Re: EPICS Python client application survey Shen, Guobao
Next: Re: EPICS Python client application survey Matt Newville
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS Python client application survey Wang Xiaoqiang
Next: Re: EPICS Python client application survey Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
