1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Python client application survey
To: [email protected]
Date: Fri, 2 Oct 2009 10:13:16 -0400
Hi All,
I am a new subscriber to the list. I'm sorry if this post doesn't get
incorporated into the existing thread.
> Sounds good.  I need to study your code.  I'm also interested in what
> John Hammonds's working on. Again, I am not at all wedded to my code
> (especially my C/swig code!).  I am more committed to having a PV (or
> Channel) object that is a fairly high-level object that supports
> user-defined callbacks and but hides most of the C implementation.
> I'm sure that this could be put on top of nearly any reasonable C
> wrapper.
Has anyone considered wrapping a Qt4 interface to EPICS with sip? QtCore's
signal/slot mechanism would provide a really simple way to handle user-defined
callbacks. Plus a Qt4 interface could be used as the basis for bindngs to
other languages, like java and ruby.
Darren
Darren S. Dale, Ph.D.
Staff Scientist
Cornell High Energy Synchrotron Source
Cornell University
275 Wilson Lab
Rt. 366 & Pine Tree Road
Ithaca, NY 14853
[email protected]
office: (607) 255-3819
fax: (607) 255-9001
http://www.chess.cornell.edu
Prev: Re: propagating value upward at init Dirk Zimoch
Next: Re: propagating value upward at init Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: FW: EPICS Python client application survey michael.abbott
Next: Re: EPICS Python client application survey Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
